HK a decidé de concurencer traxxas
Page 1 sur 1 • Partagez •
The Turnigy 1/16th Mini Rally Extreme is packed with features. Fully adjustable suspension such as front toe in and out, adjustable shock absorber locations and preloading, adjustable chamber settings, adjustable drop height, sway bars as standard and the list goes on! The Mini Rally Extreme has all the tunability of a car twice is size and double its price allowing you to truly customize the feel and performance of your ride.
The full time 4WD transmission is delivered blistering power from the 2040-4800kv Brushless motor and 25Amp Esc combination fitted as standard, no old school brushed junk to have to "upgrade" from here!
Aggressive styling, hot out of the box performance and real tunability are set to make this one of the hottest 1/16th cars to hit the streets in 2012!
Features:
Oil filled adjustable Shock absorbers
Anti roll sway bars as standard
Fully ball raced
Light weight glass fibre chassis
Tunable suspension geometry
Strong 15g Steering servo
Brushless power train as standard
Spare Parts Available
Aluminium upgrades coming soon!
Spec.
Motor: Brushless Inrunner 2040-4800kv
ESC: 25A Brushless 2~3S (with Reverse)
Battery: 2S LiPo (103x33x27mm MAX SIZE) w/ XT-60 connector (Required)
Servo: 15g Micro
Drive Train: Full Time 4WD, Twin Diff with Center Shaft Slipper Clutch
Suspension: Adjustable Oil Filled
Length: 325mm
Width: 180mm
Height: 122mm (With Body Shell)
Required.
2S 1700mAh LiPo (or larger)
Radio System (Rx/Tx)
la rally vxl n' a qu' a bien se tenir
franchement ils font de mieux en mieux, je dois avouer que je prefererait celle ci a la traxxas,
si je me prononce pas quant a la fiabilité,
vu la concpetion du chassis, le comportement devrait etre meilleur (CG bcp moins haut)... en plus des BAR d' origine
et faut avouer qu' elle a de la geule
quand on voit le prix et cui des pieces, ça peut etre top pour drifter
Features:
Fully ball raced
Spec.
Servo: 15g Micro
Length: 325mm
Width: 180mm
Required.
minirider42- pilote
Re: HK a decidé de concurencer traxxas
Sympas ! Mais perso je pense pas que ça rivalise sur le marché façe au mini vxl.. La marque inspire confiance, et là pour l'instant ça reste malgrès tout du hobby king.. Pour les non connaisseurs cela s'apparente à de la chinoiserie..
le-fou-du-vxl !!!- expert
ah mais je dis pas qu' ils vont depasser traxxas... ils aurtont toujours leur image et yaura toujours du monde pour fouttre 400 euros dans une drifteuse qui va faire des ronds devant la maison
perso, je ferai pas confiance a hk pour du tt, mais là faut avouer que c' est tentant
mettont que pour 70 euros t' as quelques lipos et les fdp... c' est cool c' est même pas le prix d' un tt01 rtr en brushed
minirider42- pilote
alor, qui va tester ???
sonic- expert
pas moi, je prefere un mini eight... ça fait tt et drifteuse a la fois
mais si je voulais acheter une petite pistarde... j' y reflechirais
minirider42- pilote
moi je pensse qu'il ne faut pas donner une image à hk et toujours garder la posistion de dire c'est de la chinoiserie. Sa ne veut rien dire tu peut avoir un truc qui vien de hk et qui est bien mieu qu'une voiture de grande marque. Pour info la ou je travail le patron a acheter en début de semaine derniére les derniéres visseuses boch et makita version pro ( 459 euros/u pour les boch et dans les 500/u pour makita) des scies sauteuse boch dans les 300 euros et il a voulu tester une sous marque une scie sauteuse à 47 euros. Hier on à utiliser surtout la scie sauteuse à 47 euros elle est franchement super ! découper avec du matin au soir du cp de 3cm et sur les deux boch qui on méme pas tourné 10 minutes il y en a une qui a griller pour un cp de 1cm. Donc une grosse marque veut pas dire super machine de A à Z il y aurrat une sur je sais pas combien qui aurrat un défault la plupart qui aurront une durée de vie normale et un petit nombre serront increvable alor qu'elle aurront toutes les mémes composants. Donc pareil pour les voitures rc il y à surement des traxxas qui ont durée trés peut de temps et surement des HK qui serront trés bien. Aprés c'est la chance qui aurrat une déféctueuse et une anormalement résistante . Aprés le titre du sujet et vraiment abusif car hk concurencera jamais traxxas!
mayov- confirmé
mayov a écrit:........Après c'est la chance qui aura une défectueuse et une anormalement résistante . Après le titre du sujet et vraiment abusif car hk concurrencera jamais traxxas!
A mon avis Mini a mit ça car ils ont sortie un "mini slash" (il a la même gueule), là une Rallye (pareil même gueule) etc, etc bien sûr qu'ils ne pourront jamais concurrencer Traxxas c'est juste qu'ils aiment bien copier des modèles existants sous leurs marques. Et c'est bien connu qu'ils le font pour tout pas que le RC...
Donc quand Mini dit "concurrencer" c'est plus par rapport à la "gueule" du véhicule, qu'à la qualité du produit (qui d'ailleurs comme tu l'as dit peut très bien être correct pour le prix).
EDIT: juste comme ça je viens de me rappeler un de tes messages:
tu ne concurrence pas Traxxas toi non plusmayov a écrit:......je fabrique des piéces pour ma traxxas ce qui me permet d'avoir des piéces solide en acier, résine, carbon et autres à prix raisonable....
Manu91- pilote
oui c'est vrais que gueul c'est copier coller mais aprés combien de marque on fait des voitures qui ce ressemble de gueul? surement beaucoups !
mayov- confirmé
Oui d'où ta mauvaise compréhension du terme "concurrencer" de Mini
Il ne parlait sûrement pas de la qualité mais du plagia qui existe entre les 2 fabricants.
Manu91- pilote
ouai aprés si une marque veut faire une drifteuse avec carro de ford fiesta ou autres si une autre marque veut aussi une direfteuse ford fiesta ba c'est pas du plagia. Ce qui ce passe aussi c'est que si certaine marque copie les carro ou les chassis par exemple c'est que le fabriquand qui fourni les piéces à traxxas ou hk ou losi enfin à tous peut casser les prix si il a pas à faire une moule spécifique pour une voiture mais si il peut reprendre le méme moule, donc baisse du coup pour hk = voiture qui leur revien moins chére et donc = voiture vendu moins chére. C'est sur c'est de l'étude de commerce plasturgie ( c'est ce que j'aime le plus dans mes cours de plasturgie)
mayov- confirmé
eh cool les gars, je disais ça en deconnant, HK concurencera jamais traxxas en effet...
mais il y a très peu d emodeles de ce type dans la production actuelle, et là on voit clairement qu' ils ont pompé le truc, l' echelle, le nom, les formes...
d' ou ce titre
j' ai jamais causé de plagiat ou de je ne sais quoi...
d' ou ce titre
minirider42- pilote
En même temps c'est une pistarde, généralement quand tu casses c'est que tu as taper quelque part genre une bordure, et là que ce soit traxxas ou HK, les 2 casseront, autant prendre le moins chère, surtout que là le châssis à l'air plus adapter à l'utilisation piste, et je dis ça en tant qu'ancien propriétaire d'un traxxas mustang.
glam62- racer expert
c' est ce qu je disais au dessus, c' est concu comme une vraie pistarde, pas comme un tt rabaissé (meme si ils ont un buggy sur cette base...)
après quand je parle de fiabilité / solidité c' est plus la trans... t' as beau pas prendre de coups, un cardan explosé ou un diff broyé et ça marche tout de suite bcp moins bien
minirider42- pilote
Oui c'est sûr, mais déjà sur ce genre de machine, tu tournes en 2S........et traxxas n'est pas mieux de ce côté là avec leurs cardans en plastique
pas faux... mais moi je fais une allergie aux 2s
ou alors y me faut un moulin de bourrin comme cui de mon ex-mini t
9400kv, là ya plus besoin de 3s pour que ça tourne
minirider42- pilote
franchement moi je préfère acheter 2 ou3 copie hk que 1 traxxas (société de consommation lol) après, j'ai un helicotptère hk et ilest de très bonne qualité...
chriskarni- débutant
ouai enfin bon chaqu'un son point de vue c'est clair que j'ai deux traxxas et j'aime bien le rusty mais je doit dire que la bandit c'est pa sla réussite je vais la vendre pour un losi 8ieght. Mais niveau combo un traxxas à 200 euros veau méme pas un ezrun à 115 euros.
mayov- confirmé
oui tu a raison et de toute facons je pense que traxxas c'est du made in china ...
Le velineon est quand même un très bon moulin !
Totorgex- pilote
moi je le trouvais sympa jusqu' a ce qu' il crame... pourtant il a jamais bcp chauffé
on doit bien pouvoir trouver un equivalent moins cher
minirider42- pilote
ba si tu veut un moulin plus puissant et moins chére le ezrun 2700kv et une bombe !!!! voir le 4300kv toujours de chez ezrun !!!
mayov- confirmé
Moi j'ai bien aimé le Velineon et pas de soucis à part un axe (c'est de ma faute) il est a quand même du couple en 3S
avec un rapport correct il va bien
Pour EzRun, le 2700 je veux bien mais le 4300 j'ai plus confiance
après 2 lipo à la Sablière
Manu91- pilote
Moi j'ai u quelque velineon , voir pas mal , jamais u de souci et je regrette même d'avoir vendu le dernier !!
Totorgex- pilote
ben pourquoi tu racheté pas le mien
sonic- expert
J'y est fortement penser .....
Totorgex- pilote
» Traxxas 1/16 SLASH 4x4 VXL
» [news] Traxxas Rally VXL
» TRAXXAS E-REVO 1/16e legerement optionné !!!!
» [Photos/vidéo]Mon Traxxas Revo 3.3
» Remplacement des connectiques Tamiya/Traxxas
Page 1 sur 1
